-   -   Tach Sender (https://www.offshoreonly.com/forums/general-q/158144-tach-sender.html)
gripit 05-13-2007 07:51 PM
Tach Sender
Where does the tach sender wire attach to on the motor? The motor is a 420 hp. Thanks
monstaaa 05-13-2007 08:23 PM
there should be a grey tach lead in the harness under the dash. if not use the grey wire on the coil.
gripit 05-13-2007 08:39 PM
Are you saying the sender wire runs to the ingition coil?
Griff 05-13-2007 09:34 PM
Yep, tach gets its signal from the neg side of the coil.
