500 EFI Spark Plugs
What is the best spark plug to use for the 500EFI? Also what should the gap be for the plug?
Thanks, Mike |
NGK BPR8ES is what is called for in the manual. The gap is stamped on top of the motor.
also MR43t standard AC marine plugs. the NGK will be cheaper
I Use The Extended Tip R43TS - Gap Should Be .035
I run the AC42ts in my 500efi whipple motor. The 43 or the #6 should be good
Spark plug cross referance http://www.dragstuff.com/techarticle...reference.html |
What do the extended tips get you? Are there any draw backs to using the extended tips?
| All times are GMT -5. The time now is 07:34 AM. |
