500 EFI Fuel Pump Problem >
Old 05-16-2007 | 05:06 PM
Fountain38's Avatar
Default 500 EFI Fuel Pump Problem
I have no power to my fuel pump relay and inturn to my fuel pump. The middle fuse (15 amp) has no power coming to it and the cool fuel pump will not come on. I have tried checking all connections that I can think of and this is where I come up empty handed. The Warning dash light (low oil pressure-low out drive oil, high heat) does not come on when you turn on the switch either.
Any one have any suggestions please. Memorial day is right around the corner and I am trying to fix it before then.
thanks
Fountain38 is offline
Old 05-16-2007 | 05:28 PM
28Eliminator's Avatar
Do you have a neutral safety? Is it engaged?
Jiggling the shifter is the first thing to try.
Do you have a kill switch with lanyard? I have had that problem before. pull it out and plug back in. I helped a friend trouble shoot his Formula last year and his were bad.
28Eliminator is offline
Old 05-16-2007 | 05:42 PM
Fountain38's Avatar
Thats a good Idea. I will check those connections. The funny thing is it just quit working since last fall. Nothing else has changed. I will check that out
thanks
Jim Diesel
2
09-03-2008 07:40 PM
Dock Holiday
6
10-10-2007 06:52 PM
Steel Outlawed
7
03-08-2007 07:05 AM
Scarabdude
0
02-16-2005 06:54 PM
Quest for Speed
4
02-12-2004 07:21 PM
