Morse cable ends...
Where can I buy the end that goes on a Morse 33C cable where it attaches to a k-plane? (used for the indicators) I previously used a pivot-ball like you would use to attach a throttle cable to a carb, but it rusted and I'd like to find a stainless one...
a few tricks....
buy a small length of fiberglass rod. cut it. drill it. tap it 10/32 thread. machine( or grind a flat surface onto one side of the opposite end tapped)and install. use a mercury throttle/ shift cable end. use a an alternate material other than the glass rod. good luck p.s or call mercury and get the original kiekafer ends. |
Hardin Marine 877-900-7278 www.hardin-marine.com:D
Any Merc dealer can get them. I got some a couple years ago.
Originally Posted by Cignificant
(Post 2133391)
I know exactly what your looking for. Its the old design and may be obsolete. If that is the case I may have one some where but God knows where. Let me know if ya can't locate them from Bam & wll look for it in the meantime. |
Thanks for your help folks. I'll see what I can dig up...
| All times are GMT -5. The time now is 02:04 PM. |
