-   -   trim tab indicator (https://www.offshoreonly.com/forums/general-q/158784-trim-tab-indicator.html)
toggle throttle 05-21-2007 10:26 AM
trim tab indicator
i lost one of the white plastic pointers on the stock mercruiser drive and tab indicators does anyone have one or know where i can get one it would be greatly appreciated
Pwrbt33 05-21-2007 11:52 AM
Did you loose the spring that goes under the white pin or just the pin? Also was it short or long?
John:D
Ted G 05-21-2007 12:46 PM
BAM has them:
http://www.mercruiserparts.com/Show_...+%284+CABLE%29
toggle throttle 05-21-2007 02:37 PM
still have the spring just lost the indicator its about an inch long dropped it down the hull when i was replacing the cable
toggle throttle 05-21-2007 02:50 PM
thanks insptech but the only problem is the parts three dollars and they want 19 dollars to ship it ill wait to see if anyone has one if not then ill order from there again thanks
Ted G 05-21-2007 04:47 PM
You could get a Merc dealer in this area to order on his regular shipment and save the shipping, it is a valid part number I believe.
