remove/clean fuel fitler seadoo gtx
If memory serves me right i think its a fuel/water-filter/sepperater all in one....you lift the front hood and take out the bin/tray....behind it under the steering should be a bulb that you unscrew and clean out.....thats it i think...i dont think theres an actuall fuel filter like you would find on a boat/car...but i could be wrong..its been a while since ive seen or worked on one
-Wally
-Wally
heres the skinny on older seadoos, as they get older the gas actually degrades the inside of the fuel lines, gunking up the filter, carbs etc.. replace all the fuel lines with good stuff, new filter and go over the carbs..your toubles should then be over for a looonnngggg time.
