-   -   Oil Pressure Issue (https://www.offshoreonly.com/forums/general-q/159172-oil-pressure-issue.html)
p.brousseau 05-24-2007 09:11 PM
Oil Pressure Issue
Ran the boat last weekend with the dealer for a shakedown, oil pressure was the same in both motors(80psi) on the way out.On the way back the port motor would loose about 25 psi when we pushed it over 5200 rpm but would come back up when we let off.Any ideas?
Pierre
the duke 05-24-2007 09:15 PM
Pierre
The oil got hot, thinned out and the pressure dropped. but 55 lbs at 5200 RPM is fine.
What filter and oil are you running? and do you know what your oil temp is.
p.brousseau 05-24-2007 09:16 PM
Forgot to mention that we had a loading up problem at low speeds with that engine we stalled it several times.The service manager sugested the problem with the oil pressure could be from the oil being washed down with fuel, he was going to change the oil and test.
p.brousseau 05-24-2007 09:17 PM
Fam filter and 20 50
the duke 05-25-2007 12:13 AM
What kind of motor, EFI or Carb?
the duke 05-25-2007 12:14 AM
If it was a Fram Racing, like the HP 4/6, ok. If it was the cheppy Frams, that wasn't helping you at all
