Question - I haven't run my engine in almost 2 yrs
1 Attachment(s)
Aside from getting rid of the old fuel, what other things should I check out or watch closely once I get new gas and batteries in?
It is a 540 with dual carbs. Yeah, yeah, I know - if I used it more, I wouldn't be asking this question.:D :D Thanks- |
Make sure pistons are not seized by cranking over by hand. go thru the carbs and check to make sure the oil pump is priming. Also replace the raw water pump.
Replace raw water impeller. Pull the spark plugs & spray some fogging oil in each cyl & turn over by hand. Reinstall plugs & disconnect coil. Use starter to turn over & build oil pressure. This is the procedure I use each spring. After running it for a few mins replace the fuel filters.
Fresh oil, and maby let the fogging oil
sit in the cylinders a few days before spinning the engine over. |
You'll have it running by next week ?
How big is the cam?? May wanna test valve spring seat/open pressures to be sure the open ones aren't weak.
Originally Posted by cig1988
(Post 2144587)
I would squirt a little marvel mystery oil in the cylinders and let it sit.
Originally Posted by Phantom1
(Post 2144804)
I seriously doubt it..................
| All times are GMT -5. The time now is 06:22 PM. |
