-   -   496 mag to ho conversion ? (https://www.offshoreonly.com/forums/general-q/160037-496-mag-ho-conversion.html)
26sonic 06-04-2007 09:26 PM
Was wondering besides changing the cam and ecu to convert a 496 mag to ho what fine tuning should be done for optimum performance after the conversion ? I asume the engines sensors and adjustments were set-up for the mag engine and need to be re-tuned for the ho set up? RAYLAR you out there ?
tblrklakemo 06-04-2007 10:36 PM
Shouldnt be anything else....ie. all the fine tuning is done on the HO ecm. I think it is plug and play.
Hot 4 Teacher 06-05-2007 03:16 PM
Correct, it is plug and play. I was pondering the same thing last year when Bob Loyd (Full Throttle Marine) asked why I would spend about the same in labor for the HO upgrade when I could do a Raylar kit for the same labor and just add a little for the parts. Raylar it was. :D Crownlines are freaking sleds, so it's still not fast, but sure sounds good now. :D
Plane Silly 06-05-2007 03:50 PM
So what were your labor cost? I hear you got a REAL good deal.
Hot 4 Teacher 06-05-2007 07:56 PM
Let's just say it was reasonable. :D
mess 06-05-2007 10:51 PM
496 mag to HO
Hey 26sonic,
I converted my mag to a HO and the only parts I replaced was cam and ecu. Chek out my thread mag to ho.
WileyCoyote 01-26-2025 12:10 PM
Looking
looking for your post
Brad Christy 01-27-2025 06:54 AM
WileyCoyote,
Assuming you're looking for an ECM...
I am in the final stages of a 496HO rebuild in which we swapped the ECM for a Holley HP ECM. I can't help you with the cam, but I will have an ECM with Whipple's stage II tune available as soon as my we are up and running with it. Send me a PM if you're interested.
For the record, you'd be very well advised to swap out your valve springs while you're at it. OEMs are only 90lbs on-seat. ARP studs, a decent set of roller rockers (which will require valve cover spacers) are also fairly cheap investments in both longevity and performance.
Thanks. Brad.
underpsi68 01-27-2025 09:31 AM
All 496 ecus are not the same. Need to know the year.
For a stock 496, I would just run the stock springs. They go for 1000+hrs with no issues. No need to reinvent the wheel.
Brad Christy 01-27-2025 09:49 AM
Under,
Fair enough on the springs.
WileyCoyote,
FYI…. Original model year of my 496 is 2001.
Thanks. Brad.
