-   -   Procharger fuel preasure issue (https://www.offshoreonly.com/forums/general-q/160230-procharger-fuel-preasure-issue.html)
snake plissken 06-06-2007 09:35 PM
Hello I have a 1999 Donzi 22zx 454 MPI Dana Headers M1 Procharger. I set my Fueal preasure at idle at about 38lbs atg WOT its about 40 lbs then when i stop its a 60 lbs so then I tweak it some more and lower it back down and it running to lean once again any ideas what going on ?
articfriends 06-07-2007 03:06 AM
THrow the junk regulator that procharger gave you with your kit in the trash,install a high quality aeromotive regulator to maintain base fuel pressure,send the return from the aero regulator to a second regulator,a cartech brand rising rate style. make sure it has good boost referenicing to manifold,I have posted plenty of pics on this,Smitty
kennyo 06-07-2007 08:14 AM
Smitty, Your going to have to write a book. I'll buy the first copy and you can make enough money to support your boating habit! Well maybe not all of your habit.
tssteph 06-07-2007 08:24 AM
there is also a issue with the cool fuel pump in the 98-99 range. There are two updates to it last time I checked. I had the same kind of issue on my scarab with prochargers. I replaced the fuel pump on one motor and it solved the issue. I also eliminated the stock regulator off the fuel cooler with a adapter from procharger. My regulators from procharger seems to work ok on both my motors.
