-   -   Shavings in oil pan (https://www.offshoreonly.com/forums/general-q/160385-shavings-oil-pan.html)
Katapult 06-08-2007 06:24 PM
Shavings in oil pan
Engine 1988 SBC FWC 500 hrs. inboard. Shavings of what looks like baring material in oil pan Yea lots of it.
Rod bearings show some slight wear,mains look very good almost like new. Engine knocks. Where else to look ?
BillK 06-08-2007 06:47 PM
How far have you taken it apart ? How does the thrust bearing look ? Aluminum piston material looks very much the same as bearing material. Seems like you need to dig deeper to find where it is coming from.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
stevesxm 06-08-2007 07:01 PM
with all due respect, why are you even asking. you KNOW it has to come apart to the last piece... just do that and the answer will be self evident. any other approach is just flat asking to have a disaster.
BenPerfected 06-08-2007 08:02 PM
It is toast...start over.
Katapult 06-09-2007 01:08 PM
Well Found a bent rod. Shaving were from the bottom of piston,Stevesxm right on .
MacGyver 06-09-2007 02:20 PM
Now find out why the rod bent. Reversion maybe?
