-   -   removing powerhead on 2.4 merc (https://www.offshoreonly.com/forums/general-q/160387-removing-powerhead-2-4-merc.html)
oldschoolfan 06-08-2007 07:02 PM
I am having trouble removing the powerhead on my merc 2.4 I have undone the 6 bolts the wiring harness cables and shift linkage and can't get it to move i had the lowerunit out about 2 weeks ago and that was simple am i missing something here? are there any tricks?
thanks
josh
JnT 06-08-2007 07:35 PM
Make sure ALL the bolts are out. I did an 89 Evinrude 225 last winter that would not seperate. I had a lifting ring in the crankshaft and jacked it up a half inch off the floor with a car engine hoist. Whacked the mid with a rubber mallet a few times and it broke loose.
Check screamandfly.com as well for tech tips.
Jim
monstaaa 06-09-2007 06:58 AM
there are also 2 more nuts under the the cowling in the very front , just over the pivot pin behind the tilt tube. you will have to loosen them and lift the power head up a little then finish loosening them as there is very little clearance between them and the pivot pin or center section housing.
i believe there are 10 in total.
there are also 2 in the bak under the area behind the coil packs.
good luck.
Jersey Tom 06-09-2007 09:52 PM
There are 10 nuts on studs. The front 2 and the back two are shorter studs and are higher up. Had to change mine twice this year.
dkwestern 06-11-2007 07:41 AM
Yep 10 bolts, also the gaskets will stick a lot more than you think. After you reinstall with new gaskets, re-tighten all 10 bolts after the first couple runs and/or a week or two as the gasket will take a set.
ziemer 06-11-2007 09:29 AM
Is it a saltwater motor? If so the studs can and will rust up good and sieze to the exhaust plate. Can be a bi-otch to separate. ;)
