Air/fuel ratio system
Is there an air/fuel ratio system that will bolt on a 496mag? :cool:
Any of the available systems will work as long as you have an O2 sensor bung welded on, or have an adapter plate made to fit between the manifold and the riser. I welded one into my riser. Not the easiest welding task for an amatuer like myself due to the fact that you have to put it in a double walled riser, which means welding on the inside of a tube. A good tig guy should have no problems.
Originally Posted by bcarpman
(Post 2160012)
Originally Posted by DPA
(Post 2160678)
I see dana marine has spacer plates for an o2 sensor....:evilb:
Good find. Not sure these would work with a 496 exhaust though. Looks like they're made for Dana's Torque Flow exhaust. That's probably why no one makes spacer plates: Every exhaust is different. |
Just built new EFI motors and had O2 bungs welded into CMI's for tuning. Find a local shop that can weld them in. The bungs are only about $10-15. (I'm not sure I would want them hooked up all the time though)
Originally Posted by t500hps
(Post 2161134)
Bump ops wrong thread |
I bought the FAST dual O2 system for a dyno, so it came with 22ft cables
(Post 2161527)
Yep, you absolutely don't want them in all the time. With the moisture in the exhaust on a boat, I wouldn't expect them to last very long. I only put one in when I'm using it.
To the OP, there are two parts to your answer. One is you need either a spacer to be placed between the lower manifold and riser/elbow OR a bung welded into your particular exhaust system. You then need one of several wide band kits on the market. I use the Innovate MTX-L. They have a new model and a dual channel as well. |
I took my headers to a local welder and showed him this thread. https://www.offshoreonly.com/forums/...sor-bungs.html I run my wideband all the time to keep an eye on things. If you burn through O2 sensors then yank them out after tuning. |
getting the 02 to live as any water hitting it kills them quick...ask me how I know...will be your biggest issue
Some people have had great luck using the sensor extender/heatsink and others here will call it expensive voodoo that doesn’t work. Mixed results for different engines. https://www.summitracing.com/parts/i...hoCMnMQAvD_BwE https://cimg7.ibsrv.net/gimg/www.off...15ade6b40e.png |
Does that thing work?
Originally Posted by Baja Rooster
(Post 4649171)
the daytona sensors dual wideband kit is nice. You can use the monitor to live view, or live view on a laptop screen. Datalog, and so on. |
Originally Posted by Swamplizard
(Post 4649193)
| All times are GMT -5. The time now is 08:36 PM. |
