No there was no bluing - just teeth looked broken on cam gear. The chain looked fine and also the lower gear. The wrist pin bushings looked hammered but i figured that was from full throttle extended runs.
Smitty,
What did you end up doing here? I was looking and wondering about this same thing last night on a Dart that I'm building up for a friend. Also, I had to run a die over the galley plugs to get them to go deep enough to avoid the hitting torrington bearing on the back side. A tap would have been easier but I didn't want to chance any debrit getting into the galleys as it is in the assembly stage. You would think the thread depth would be inspected at the foundry. Dave |
I have a boat load of Dart blocks out there with Cloyes timing chain sets and ZERO problems. There is plenty of oil being thrown around were lubrication up front is not a problem.
Originally Posted by Nordicflame
(Post 2393058)
Smitty,
Smitty,
So what is the problem?? You have great oil pressure, bearing clearence is perfect, and your worrying? I would run Pennzoil 25W50 racing engine oil with those bearing clearences. It would be ideal to see 80-85 PSI , but 100 will not hurt you. I run 165 psi oil pressure on blown alcohol applications. Oil pressure is your friend. I do not agree with your .050 hole theory. Your going to bleed off a ton of oil. |
Also a little note: The new Melling HV Blueprinted oil pumps do have a higher spring rate on the bypass valve and produce more pressure than earlier models.
This thread is interesting, I have the same problem with a 540 I built. At idle cold I will see 60 to 90 psi, anywhere off idle it pegs the oil pressure gauge at over 100 psi. I read in another thread that ideal oil pressure is 10 psi per 1000 rpm that you turn the engine. My engine is set up to turn a max of 5600 rpm, as propped now I see 5200 at wot. It would seem to me that anything over 60-70 psi is too much oil pressure. Not that it will hurt anything, but doesn't it rob hp to turn that oil pump? If I had 10,000 psi oil pressure, what hp would be required to run the oil pump then? I am thinking about putting a standard volume pump back in the engine just to see if my oil pressure calms down to 60-70 psi. Before I do this, what do you guys think? Is there any good reason to run real high oil pressure on an engine that never goes above 5300 rpm, n/a 540?
Interetsting thread. I use the Dart blocks and use the regular High volume melling pumps out of the Summit catalog. Havn't seen any problems. Oil pressure is around 80 at 5500 rpms. I know there is no oil problem on the front because we had front seal pop out and oil was everywhere.
Originally Posted by Nova 26
(Post 2394195)
MR, I don't remember exactly, I think it was .003 on mains and rods. When I built the engine, a long time marine engine builder set it all up and I remember him saying that it had to be "loose". He even had what my wife would call a really "cute" little bore gauge that he checked each valve guide bore with and made sure that there was proper clearance between stem and guide. I used canfield heads and several of the guides needed to be loosened up. Anyway, I think the clearances are all correct for the marine use it was built for.
My question is about the oil pressure issue, I really do value the help from you seasoned engine builders, THAT I am definitely not! My oil pressure, as I said starts out at about 100 psi but if I run it hard for 5-10 minutes straight, it starts to drop. I've seen it go all the way to 30 psi. Gen 6 block, at first I thought it was the oil bypass in the pad. Changed that to the 30 psi bypass valve, no change. I thought that maybe the high oil pressure was causing the oil cooler and filter to be bypassed. At this point I am wondering if I should just go with a standard volume pump. Is there a reason to run high volume and pressure in an engine that only spins to 5500 rpm? As I posted before, I would think that a high volume and pressure pump takes significantly more hp to turn at 5500 rpm. If they aren't needed, why use them. Can I use a standard volume and pressure pump? What advantage does high oil flow give you? |
| All times are GMT -5. The time now is 07:01 PM. |
