Stroker crank install
1 Attachment(s)
Look at the poor crank! I couldn't believe my eyes! I've seen cranks with 1 hole or 1 plug, but this is beyond my comprehension. The picture doesn't show the extent of the holes very well... they are different diameters at different depths. The flywheel had material removed as well.
One thing for sure, right or wrong, the guy spent a lot of time on this. www.strokermotor.com DES DG3-425 4340 Nitrided BB Chevy 496, Ext. Balance, 4.250" Stroke, 2.20" Crank Pin, 6.385" Min. Rod Length, 2pc Rear Seal |
1 Attachment(s)
Also, everybody and their brother told me I was going to have to clearance the block. I wanted to do this before sending the block for a bore, so I just layed it up there (with some bearings and oil) and went to start marking off where to grind, and, and, and, I can't find anyplace to clear?? there's at least an eighth inch clearance here. Are these H rods that much smaller? Or am I missing something?
4.25" in a BBC stock block does not need to be clearanced.
Originally Posted by evelkevin
(Post 2166803)
I'm guessing the "I" Beam rod with the thru bolt and nut need the clearance work. I don't have one handy to compare, but the H beam appears to be a lot smaller in that area. If so, it's good info for the next guy... either pay $ to clearance the block or pay $$ and upgrade to H beam rods. If you need longer rods anyway then it's a wash.
Originally Posted by 1BIGJIM
(Post 2166973)
Mine did.
Originally Posted by ghittner
(Post 2168352)
Mine didn't.
jmherbert:
Who is your machine shop? |
I had to notch the block AND take about a 1/4 inch off the crank throws then have it rebalanced.
Originally Posted by jackhammer
(Post 2165280)
Originally Posted by vtec
(Post 2171682)
jmherbert:
Who is your machine shop? http://jrmotorsports.com/ Their customer service is top notch, They have bent over backwards for me more than once due to circumstances beyond their control. Ask for Axel Andreasen, he does all of their machine/engine work. Very knowledgeable, and extremely helpful. He is busy, so sometimes he is hard to get a hold of. The bulk of the motors they do are small blocks, but they still do a fair share of big blocks. While marine is not their specialty, they more than know what it takes to make them. |
Originally Posted by jmherbert
(Post 2168407)
My machine shop which does mainly does race car motors, hundreds if not thousands a year told me that some block castings need it and some don't, even from the same generation/year/etc. The only way to know for sure is to mock it up, or clearance it anywho.
thousands:eek: How many people work there? |
Originally Posted by Strip Poker 388
(Post 2174151)
Maybe not quite thousands, but its a lot.:drink: I think they did 300-400 short and longblocks last year. He told me it was a record #, and they are going to crush that record this year. I think they have 10-15 in the machine/engine shop. They just lost a guy to a Nextel cup team. When I would have some work done, and I'd say I am not in a hurry, it'll take them a week or so. If I was in a hurry, they'd have it done in a few days. I spent a lot of money there, though |
(Post 2174393)
I think they did 300-400 short and longblocks last year. He told me it was a record #, and they are going to crush that record this year. I think they have 10-15 in the machine/engine shop. They just lost a guy to a Nextel cup team. When I would have some work done, and I'd say I am not in a hurry, it'll take them a week or so. If I was in a hurry, they'd have it done in a few days. I spent a lot of money there, though wish we had a shop like that here |
| All times are GMT -5. The time now is 03:05 PM. |
