Cutting Dash - What to use? >
Old 06-17-2007 | 10:04 AM
monstaaa's Avatar
coiling will not be a problem. just make sure you tie wrap the coils , and also the cables them selves. dont let them flop around anywhere as this will throw off their accuracy.
monstaaa is offline
Old 06-17-2007 | 10:10 AM
jayhawk261's Avatar
Thanks for all the help guys! After thinking about it, I doubt if I have the room for the jig saw where I need to cut. I think I'm going to go with the air reciprocating saw. Those are small and pretty much vertical. That should give all the room I need. Well, off to buy new tools soon!
Thanks again!!
jayhawk261 is offline
Old 06-17-2007 | 06:23 PM
Plum_Crazy's Avatar
Thanks again!!
Suit yourself. But, I'm telling you, the Dremel cuts through 3/4" gel and plywood pretty easy with a tile cutting bit. Plus, it's simple to make fine adjustments. Last winter I installed a DMP billet glove box. Because it was larger than stock, I had to cut the entire opening through about an inch total of plywood, fiberglass, and gelcoat. I used the same tool for the cup holder, too.
Plum_Crazy is offline
Old 06-17-2007 | 08:17 PM
eyezlee's Avatar
Get the RotoZip tool. Its way more powerful than a Dremel. Lowes carries them.
eyezlee is offline
Old 06-17-2007 | 09:18 PM
Pantera24's Avatar
Rotozip is the way to go!! Works awesome but becareful or you will lose a finger quick.
Pantera24 is offline
Old 06-17-2007 | 10:14 PM
jayhawk261's Avatar
Tabs indicators are installed. I picked up the Chicago Pneumatic air reciprocating saw. It cut through the dash like butter! Nice nad clean as well!
Bad news, I put the tabs all the way down to get the plugs out of the brackets where the cables come through. I get the starboard cable through the hole and start getting it prepped for adjustment. Starborad tab no go up! I got real frustrated, threw some things and then completely finished the port side. Came inside and did a search on my problem. Posts sounded like a solenoid. I went back out and hooked up my remote starter switch to the up solenoid and up it went! At least I was able to finish the install and get the cable waterproofed. I can now put it on the water at least. I'll have to get the solenoid changed out pretty quick though so I can actually use my indicators! I'll try to post some pics.
Thanks for all the help everybody!!
Old 06-17-2007 | 10:56 PM
jayhawk261's Avatar
Pics
Attached Thumbnails Cutting Dash - What to use?-misc-pics-011.jpg   Cutting Dash - What to use?-misc-pics-012.jpg
THEKID29FEVER
Fountain
1
05-19-2008 05:29 PM
oldschoolfan
Detailing, Painting, & Fiberglass
4
02-10-2008 06:05 PM
TCOUTLAW
1
06-28-2007 12:10 AM
jayhawk261
Superboat
12
06-19-2007 11:59 AM
powerguy
24
01-02-2005 08:33 PM
