imco drive
What is the most obvious way to tell from a regular imco drive from a 2" shorty or is there a diffrence?????
If you look at the lower, where it meets the upper, all the way in front on the flat surface, above the bullet, it will say -2.
Upper half is the same. Lower is significantly shorter and pretty obvious.
on the minus 2 , the section of the casing above where the prop is is significantly different. as in gone,
Thank you very much i looked and it said -0 so that means that it is a regular inco ...correct??? thanx for the help:drink:
yep, standard length
ask Docmanrich....:eek: :D
J/K |
| All times are GMT -5. The time now is 02:56 PM. |
