-   -   Reading oil level on the stick... (https://www.offshoreonly.com/forums/general-q/161546-reading-oil-level-stick.html)
BadDog 06-21-2007 03:36 PM
OK, this will seem like a stupid question but I have to ask. Gen 6 stock pan and stick. When checking the oil with engine at level one side of the stick says full and the other side has notch in it half way between F and L. The side of the stick that says F and L reads full and the other reads half. I understand why this is that way due to the angle of the stick striking the oil level. Think of how when reading a graduated cylinder with liquid you ignore the meniscus in your result. The oil climbs the stick as it would in a beaker more so on the side facing the oil pan bottom.
Which side of the stick did GM intend for us to read? I usually keep it saying half on one side and F on the other.
ghittner 06-21-2007 11:58 PM
Read the back, it has always been more accurate for me. Ford, Chev, Pont. Even trannies, read the back....
hoozeyurdaddy 06-22-2007 08:03 AM
It all depends on if you have oil to add as to which way you install the stick, ha-ha. it's probably better to run 1/2 a quart more than less.
