-   -   Idle surge 502 EFI...HELP! (https://www.offshoreonly.com/forums/general-q/161567-idle-surge-502-efi-help.html)
lilredboat 06-21-2007 08:10 PM
OK, did the heads, exhaust, roller rockers, programmed ECU, now have a nasty idle surge dropping from 500 - 110 rpm. Tried adjusting both throttle blades, playing with fuel pressure and nothings working. Anyone ever fix this before?? Please Help! Thanx!
HiPerf2000 06-22-2007 12:52 AM
did you forget to mention a blower ???
Pwrbt33 06-22-2007 06:00 AM
I have had this happen before when we had the ecm reprogrammed. Once I had to just let it run and idle for damn neer ever and the other I had to send it back to have them fix it.
john:D
lilredboat 06-22-2007 08:02 AM
no blower, and i clocked about 2 hours on the hour meter on the hose, does it really take that long???
HiPerf2000 06-22-2007 10:16 AM
Thought a whipple was going on ??
BenPerfected 06-22-2007 10:42 AM
Did you do an porting work on the intake manifold?
mjb 06-22-2007 10:45 AM
Sounds like your IAC needs adjusting. That is usually needed after reprogramming your ECM. You will need a scan tool. Make sure your base timeing and fuel pressure are set correct to begin with. Then after the engin warms up, set the IAC to about 35 to 40 counts by adjusting the stop screw on the promary throttle blade. That more than likely will solve your problem....assuming your IAC is in good working order. If that doesn't work you may need to check the calibration of your TPS....but we'll save that for another thread.
