Broke my bravo Bell Housing Assembly
Well yesterday I was out in my scarab. On the way back in I noticed that steering down the canal was loose ( I have full hyd steering) not normal for my boat. Well we pull the boat out and looked the bell housing assembly broke around the hindge pin on the starboard side... Is that normal, what could of caused it beside jumping waves?? Thanks Kyle
This is what broke / any one have one cheeper then this>>> http://mercruiserparts.stemtostern.c...umber=%2017721 |
Originally Posted by kmiller
(Post 2174650)
I was thinking the same. I will disconnect the ram and look tomorrow. It was a add on that I converted to full last year.. Thanks Kyle
Is it an HP or stock housing ?
If you broke the Bell housing, than you better check the Ring very closely, make sure it's not cracked. I have seen alot of this. I do have a fix for a lot of them and have had very good results. We have some used parts, if you don't want to by new. Also if you want send the complete Gimbal I can possible update it, if that hasen't been done already. Give me a call at; 954 237 0332
Stock 1990 bravo w/ drive oil fitting
John, Do you have a used Bell Housing? If so I need one.
1 Attachment(s)
I have a stock bell housing..make an offer.
100.00 shiped
| All times are GMT -5. The time now is 12:09 PM. |
