-   -   Help? Bravo 1 Question (https://www.offshoreonly.com/forums/general-q/161748-help-bravo-1-question.html)
rssteiny 06-24-2007 01:07 PM
Was Running In A Poker Run Saturday Pretty Rough Water In My 32 Active Thunder With 500 Hps And Bravo 1 Drives Was Running About 65 Mph And Felt The Boat Slow Down So I Shut Down And 1 Drive Has No Forward But Reverse Works Fine, If I Shift It In Forward And Try To Spin Prop IT Spins Free No Noises At All, But If I Try To Spin It Backwards When It Should Lock It Does Not And It Gets Tight Then Loose (Clutches Maybe.:(
Thanks For Any Help
rssteiny 06-24-2007 04:32 PM
anyone
NorTech50 06-24-2007 08:02 PM
Shift cable or cluth bec the uper shaft has a spiral and thats what hold it in gear the pressure from the motor running
johnnyboatman 06-24-2007 09:15 PM
broke the floor out of forward gear.
East Coast B 06-25-2007 05:55 AM
Raystown is just days away! Tic Toc Tic Toc! Time for the backup drive!!!
All you need is one drive to get you to and from the cove!!!
hehehehehe
Got a number for your groups houseboat yet?
rssteiny 06-25-2007 06:40 AM
never had one apart is it a hard fix and where do i start. i do all my own engine work but yet to tear into a drive.
thanks
John the Drive Man 06-25-2007 07:44 AM
It's in the upper. Possible the floor of the driven gear. Why don't you send the drive to us we can turn in around very quickly. We are a Merc. Service center. Give me a call at;
954 237 0332
Fountain38SC 06-25-2007 09:36 AM
I agree, you probably blew the floor out of the upper gear. Pop the top cap and take a look.
rssteiny 06-25-2007 11:01 AM
so to take a look i dont need to pull the drive , just the top cap and if it is that then do you need to pull the drive and tear it down orcan you do it from the cap. nalso is there a 3 bolt plate you can remove and see the shift componets.
thanks
rssteiny 06-25-2007 02:48 PM
pulled upper cap and plate with 3 bolts on the back and as far as i can tell everything looks fine all gears shift arm is working no metal filings in oil. is there something i can check mor thorough while im in there. thanks
