502 Head, Rocker, Intake torque specs?
Hi there,
I've got a 2001 502, which I suppose is gen VI. I am replacing cyl head gaskets and am ready to re-assemble. Anyone have the torque specs for heads, intake and rockers? Also, should I be using any loctite on the rockers? Thanks! |
Head tq depends on the lube used. Using ARP bolts and ARP lube, its 65 lbs for all the bolts. Using ARP bolts and 30w oil, its 85 lbs. The rocker arm shoulder bolts go to 40 lbs, and the intake goes 25-30.
thank you!
