454 mag rpm question
Ive got a fresh 454 mag in my 26 scarab excel w/alpha drive, 19" three blade turbo prop. Ign set at 34 total, engine has lunati 420 replacement cam w/hyd flat lifters. Stock alum mag intake with resh rebuilt roch carb, and cast exhaust, with fast glas risers. The engine has 22 hrs, has strong and even compression.
Question is- im showing 4300 max on the tach, and about 51 mph on the speedo? Any idea of what to look for here? Im more concerend about the lack of RPM, with such a flat prop. |
sounds like you may be down on power just a little, what heads are on the engine...the 19 isn't far off if the drive has a 1.32 gear ratio
Check out the thread 454 losing spark on 4 cylinders. Might answer some questions.
I checked compression both hot and cold and its strong and even on all cyls. The heads are the mag 188's, although I kept the stock rocker arms. Could there be binding with the valve lift on that cam?
Have you checked to make sure your thottle linkage is opening the carb all the way?
Originally Posted by mark30h
(Post 2179683)
| All times are GMT -5. The time now is 01:54 PM. |
