-   -   water pressure gauge hose (https://www.offshoreonly.com/forums/general-q/162091-water-pressure-gauge-hose.html)
eliminatethis 06-28-2007 07:53 AM
the livorsi kits come with plastic 1/8 hose do not like that copper is also out of the ? I have seen some black (rubber) hose on some theads in the past on oso looks like a speedo hose of some sorts was a slip on with nylon zip tie . any brands or part # out there
tssteph 06-28-2007 07:59 AM
Mine had a hard plastic hose similar to ice maker water hose. Check your local hardware store.
stevesxm 06-28-2007 07:59 AM
i used the -3 push on aeroquip( the cloth/ rubber hose.. not the stainless) . a bit expensive but better then having the thing fail inside the bulkhead... those skinny nylon lines work alright except that the ends that attach to the gage and sender are only good for a couple "attachments" . once theyve been tightend more than that they are crushed so far that you either cut the hose or it bottoms before it seals.
the duke 06-28-2007 11:02 AM
Mine are the black ones that they use for underground sprinklers from Lowes. Not sure of the material, but its inexpensive, and rated for a lot more pressure then I will ever need. Plus it hides better than the vaccum line does.
Reckless32 06-28-2007 11:04 AM
Plumbing section of Home Depot/Lowes in the ice-maker section.
monstaaa 06-29-2007 07:12 AM
it's -4 push loc. comes in many colors. manufactured by parker. done.
