rust!!!!!!!
Anybody know of a product that will remove rust stains on a boat that is safe to use on gel coat???.......and where i can find it??????
This is the best stuff I have ever seen. This stuff actually smokes when you open the bottle.
http://www.westmarine.com/webapp/wcs...33&classNum=34 |
Originally Posted by checkmate454mag
(Post 2181144)
Would something like CLR work?
I too have a bad rust stain on the non-skid deck. Years ago I used a commercial toilet cleaner called "Gun Smoke" it would produce smoke (acid vapors) as it was applied. Sure was strong but it did the job. |
I just removed some rust from my gelcoat yesterday. theWorks toilet bowl cleaner. It works real fast. Wear rubber gloves, squirt it on and use either a scotch brite pad or the sponges side. Rinse well with water.
It did take off the rust stains. I tried the CLR toilet boawl cleaner and it did not work. |
bleach
Oxalic Acid is also excellent and safe. It comes in a powder form, add water and apply.
thanks for all the import i will start trying
| All times are GMT -5. The time now is 04:40 AM. |
