-   -   Coolant leak? (https://www.offshoreonly.com/forums/general-q/162518-coolant-leak.html)
docmanrich37 07-03-2007 09:38 AM
Coolant leak?
I just had my 525efi/whipple charged engine that was just rebuilt.It has 7 hrs. on it and its leaking coolant out from the coolant tank cap,is what it looks like.I have changed caps from 1 engine to the other and its still leaking when running.Installed cometic gasket on it and have been told it's not a leaking head gasket.The temp. is fine.Have checked all hose clamps and can't find anything else.Should I put some stop leak in it and or a leak down test.Thanks
OldSchool 07-03-2007 09:55 AM
At what point do you forget to put in the plug and go for a ride????????????????????:D :drink:
docmanrich37 07-03-2007 10:03 AM
Can't to busy workin on it all the time.It's been running great just trying to get the little things done before the p.r. next weekend.
OldSchool 07-03-2007 10:11 AM
Good to hear that it's finally running. That had to be a huge test of your patience!
Be safe at the poker run!
Reckless32 07-03-2007 11:01 AM
Is it the heat exchanger? or reservoir? Leaking externally, or internally?
docmanrich37 07-05-2007 07:45 AM
Its leaking around the outside of the cap around the coolant tank.To much pressure maybe.Plus I hear a whistling sound when I shut the engines off,like a leaky tires does.
