Molded Hose From Power Steering Cooler To Bellhousing
1 Attachment(s)
anyone have a part # , i just got back form napa and really can't find a hose that has 2 molded 90's to fit..
checked bam's site and can't find any diagrams or part #'s with a bellhousing cooler with a in-line ps cooler on the starboard side... seems i need about 5" in height and about 7" or so long molded. i have a box of the hardwall but it will not make those 2 tight bends in such a short distance.. softwall just collapses.. |
I suggest two hose 90's joined together with a 3" piece of SS tubing with two clamps. Mercury used this rig on long runs on the port side of some engines. These three pieces should allow for a perfect fit...work good, look good.
3 Attachment(s)
i actually had luck this afternoon...:eek:
went to o'reiliey's and told the counter man , hey , i'm playing water works engineer on a boat and i need something that has 2 90's ,etc... and another piece that has a slight round out... cat say's , come in the back , i have a wall of hoses...15 minutes of looking ...found what i thought would work.... part# gates 21025 for the rear-- 2 true 90's part# gates 21171 at the front-- had the right contour had to cut a few inches off and fit up, the radius on both is not forced at all... the hose around the engine mount may need a extra piece for rubbing and on the corner of the pan... had to take a break from those AN fittings... |
| All times are GMT -5. The time now is 02:28 PM. |
