-   -   Help with my 502 oil bypass?? (https://www.offshoreonly.com/forums/general-q/162867-help-my-502-oil-bypass.html)
paulkairis 07-08-2007 11:57 AM
i,ve read a few things about an oil bypass in here but nothing detailed enough to know whats going on here. i've got a 502 from the early "90s" and it runs the oil temp up if i cruise over 3500 rpm. i felt the oil lines as soon as the oil got to 150 and i feel some heat so there has to be some oil passin thru but how much?? if i keep my revs down the temp stays under 220 also i've heard that if i'm bypassing the (cooler/ filter) that i might have 5-10 psi less oil press. which would be right in line with what i'm seeing here!! one more note, i just had the bottom end opened up looking for a low oil press. problem and found that the engine builder was heavy handed with the locktite which left a nice size piece stuck in the oil pump relief. that got back +or- 15psi of my missing oil press.
Turbojack 07-08-2007 09:52 PM
Do a search on oil bypass. There is much info on this subject. I had posted pictures of the passages in out and around the oil filter. I believe the good bypass you need is the 35psi one.
djtalon 07-09-2007 09:54 AM
what were your signs with the oil pump problem? I am losing oil pressure above 4200 and checked everything but the pump.
paulkairis 07-09-2007 01:17 PM
i just had low oil press. across the board, starting with about 0 at hot idle!!
