-   -   Engine vacuum (https://www.offshoreonly.com/forums/general-q/162901-engine-vacuum.html)
CC247 07-08-2007 08:19 PM
Engine vacuum
Anyone ever watch a vacuum gauge while running? What rpm and vacuum do you see? If my boat was a car I'd say I've got a plugged up converter. Only 3" at cruise to Wot, what gives?
oldandtired 07-08-2007 09:56 PM
Ideally, you should see 0 at WOT. I have never put a vacuum gauge on a boat, but high vacuum=idle/low throttle position, low vacuum=power/high throttle position. Try measuring the vaccum at your cruise rpm with the boat in neutral and you'll see plenty of vacuum. I haven't hooked up a vacuum guage in many years, but I don't remember using one for anything other than diagnosing at idle/very low throttle positions.
Rene
CC247 07-09-2007 05:45 AM
I see 11" at idle, 14" at 2500 in neutral. As soon as I drop it in gear I see 5-6" at 800 rpm. Then 3" at cruise 3000rpm.
madbouyz 07-09-2007 01:42 PM
My old 351W had one and it was a great tool to let you know if you needed a tune-up . There was other things they are good at warning about but I guess you have to know what the signs are. A friend tried to install one on his 289 Holman Moody but the cam selection resulted in a gauge that constantly jumped all over at idle.
If I remember correctly mine would pull 20" at idle rock steady.
Of course, the more the butterflies open up , the lower the gauge goes !
kennyo 07-09-2007 02:03 PM
Your gauge might be bad.
CC247 07-09-2007 07:43 PM
blown head gasket:(
