-   -   Hit Rocks,tore Drive Off,checking Coupler (https://www.offshoreonly.com/forums/general-q/163720-hit-rocks-tore-drive-off-checking-coupler.html)
awsomethunder 07-17-2007 11:18 AM
well had a problem with a rock pile this weekend.broke the drive off the back of the boat.insurance guy came out and looked at it.is there anyway to see if the coupler is damaged or spun?just don't want any problems 2-3 months down the road
Knot 4 Me 07-17-2007 01:33 PM
Shine a flashlight in through the gimbal housing and you can clearly see the splines in the coupler.
awsomethunder 07-17-2007 01:43 PM
yea but what about the rubber spinning?
MOBILEMERCMAN 07-17-2007 02:07 PM
It will be really hard to tell for sure. If it spun enough to make heat you might see some sign around the edges of the rubber but seems unlikely you will be able to see it while its in the boat. The rubber part is pretty tough. I would think it would take one quick shot.
Jim
BadDog 07-17-2007 02:41 PM
I would bet it is compromised. Have it replaced on your dime if need be.
Knot 4 Me 07-17-2007 03:02 PM
That would be more difficult to tell from that vantage point.
Trippin 07-17-2007 05:29 PM
Remove the motor and replace the thing, your insurance ought to pick up the cost because it is directly related to the drive damage. Not to mention it is a good idea to yank the motor and check for signs of internal transom damage as well. I've worked with many insurance companies on damage just like yours, it's covered 90% of the time.
ghittner 07-18-2007 02:37 AM
279.00 new on Ebay. Change it.
the duke 07-18-2007 11:23 AM
Get the insurance company to let you pull the engine to check the inner transom assembly for damage. You can't see it with the engine in. Been there done that. Both the coupler and the transom assembly had to be replaced because of damage.
Pat McPherson 07-18-2007 11:35 AM
I hit a log going about 60 a few years back.
Same as yours; ripped the drive right off the boat. We didn't know it was still there until hulling the boat. The drive was hanging by the stearing pistons.
The coupler was fine but the transome assembly was shot.
Pull the engine and check everything...
