Seeking Thunderbolt V6 Ignition Module >
Old 07-30-2007 | 08:57 PM
cuda's Avatar
Originally Posted by SmallPP
Cuda thanks for the words. Do you know why a V6 module will not advance as far as printed? I see some people use them here. What is the science with them?
I should have bought your 242, I called on it several times, but never made it your way to see it.
I don't know why, but I wouldn't doubt Kurt (Biggus). He knows his stuff.
cuda is offline
Old 07-31-2007 | 08:28 PM
I have a used TB IV distributor, with a new cap and rotor, and a TBIV V8-22 module, that provides 22* of advance. Let me know if you want em.
SneakyPete is offline
Old 07-31-2007 | 09:26 PM
There are 2 22* modules. One gives 22* by 3500rpms and the other 4500rpms.
For an other than stock engine with upgraded cam, I would either get a V6 module or an HP module. It will allow more initial timing and help with idle quality.
Griff is offline
Old 08-01-2007 | 09:36 AM
Thanks for the lessons. How do I tell the difference between modules, which one gives the advance earlier? I'd prefer that one.
My motor (5.7L, 350 Vortec Roller) is using the largest recommended Crane marine roller cam 109831 (HR-284-2S-12 IG), Edelbrock 750 carb, Edelbrock air gap Performer RPM, Vortec heads with guides cut down for increased lift, Crane recommended springs, full roller stainless Comp Cams rocker arms, aluminum GLM manifolds, thru-hull 4" exhaust. Short block is stock, but fairly high compression from 99' Vortec truck (9.5 or 10:1 if I remember right). Freshly re-ring, HV oil pump (I regret this).
This in a 1984 17' Formula, which originally had a 4.3L V6 4 barrel in it (did 50mph as tired as it was with a 25P prop).
I have so far not purchased any. Had Mallory Pro-Comp 9000 magnetic, but it has failed twice. Once just by leaving the key on! I would prefer to get one soon, and one with a V8-24 module with early advance curve to help the cam, which is a bit large, but pulls great over 4000rpm. Boat is now running over 65mph with V6 1.84 raitio and 25P @ 5700rpm, I have not had time yet to switch to 1.5 ratio.
When I start it at the launch, people come running and asking what is in it. I tell them it is a 4 cylinder, running on 3.
Those who have it for sale, please let me know or PM me. Thanks again.
SmallPP is offline
Old 08-01-2007 | 10:07 AM
The V6-14 module gives only about 10 degrees of advance because it "thinks" it's firing 6 cylinders, not 8. It determines rpm and degree advance by counting firing pulses. It also cause the ignition curve to shft to the lower rpm range.
If you get one, set your total timing at 3000rpm and dont wory about the initial. Total should be around 34 degrees depending on the engine build.
The other modules:
V8-22, 22 degrees advance in by 3400 rpm
V8-22A 22 degrees by 4400 rpm
V8-24S 24 degrees by 44000, but 20 of that is in by 2000rpm
V8-24 24 degrees by 3700rpm
V8-20R 20 degrees by 5000 rpm
These are all from Mercs manual.
Gary
rdoactive is offline
Old 08-01-2007 | 11:14 AM
The V8-HP module gives 20* advance and all in by 3000rpms.
Griff is offline
Old 08-01-2007 | 12:42 PM
Super information, thank you. I'm looking to have it all in under 4000rpm, the boat is very light so risk of knock is virtually zero. Now just need to find one used !!!
As an added note, I installed a nitrous oxide RPM switch to add a third mode of my exhauts diverters. No, I can switch them ope, closed, or automatically open above a set RPM.
SmallPP is offline
pettem
07-02-2008 06:23 AM
Switzer SS240
3
07-02-2007 04:24 PM
Switzer SS240
17
06-22-2007 12:01 AM
JohnJan
2
08-31-2004 06:26 PM
TROUBLE MAKER
5
05-03-2003 01:13 PM
