-   -   Seeking Thunderbolt V6 Ignition Module (https://www.offshoreonly.com/forums/general-q/164023-seeking-thunderbolt-v6-ignition-module.html)
SmallPP 07-20-2007 02:01 PM
Hello, I apologize for probably not placing my writing in the correct spot, but classifieds seemed to be full of new products only, so I thought I would try here.
Have late model mild-build 350 (5.7L) with Vortec roller block, Crane roller marine cam, Edelbrock 750 carb, etc... estimated 400hp/400ft-lb @ 5700rpm in 17' Formula. Runs really good, and a pinch over 65mph still on incorrect V6 (1.84) outdrive ratio, changing to 1.5:1 soon.
I was running a Mallory Pro Comp 9000 distributor with internal magnetic pickup and module, but it is very unreliable, has failed twice so far. Internet is full of failed modules, so I am chalking it up to poor design.
Seeking used MerCruiser V6-xx(24 hopefully) ignition module to use with Thunderbolt distributor. I want the V6 as it will pull the timing curve ahead by 33% over V8 module.
Thanks.
jmherbert 07-20-2007 02:50 PM
I've got one. Its a 1987 350 Mag.
Email me @ [email protected] if interested.
SmallPP 07-20-2007 03:21 PM
Is it for a V6 enigne? I want one from a 4.3L, not a 350 (5.7L). I am going to use a V6 module on a V8.
jmherbert 07-20-2007 03:39 PM
When I get home, I will look at it to be sure, but I'm pretty sure it says "V6-24" on it.
I am flying today, but should have the info by Saturday or Sunday.
Biggus 07-20-2007 05:03 PM
If it's a V-6 module, it will say V6-14.. But, when installed on a V8, it will only provide 8-10 deg advance.
cuda 07-20-2007 09:44 PM
1 Attachment(s)
You probably want a "V8 HP", which gives 20 degrees of advance.
SmallPP 07-30-2007 02:04 PM
Still Seeking
Hi folks. Still seeking a used MerCruiser Thunderbolt V8 distributor, and module. Not sure if I want V6 or V8 module, seems a little confusing, some say V6 does timing advance earlier, but another said it will not advance as far as stated. I'm not sure about this.
If you have a used but working V8 setup, I'm ready to buy. Boat down for 2 weeks now. Thanks.
SmallPP 07-30-2007 02:06 PM
Cuda thanks for the words. Do you know why a V6 module will not advance as far as printed? I see some people use them here. What is the science with them?
I should have bought your 242, I called on it several times, but never made it your way to see it.
jmherbert 07-30-2007 02:42 PM
I replied to your email last week, but it must of not gotten through. I have the V8-24 module. I do not have a good distributor though. (I have one, but the pickup is bad, and the shaft bushing is about shot)
If you are looking for both, you may want to consider a MSD Marine RTR (ready to run) or a DUI distributor.
Let me know if you want it (the module)
Griff 07-30-2007 04:35 PM
There are several different V8 modules with varying timing curves. Some curves are 20*, 22*, or 24* and they vary on when they are at full advance between 3000rpms and 5000rpms. What kind of curve do you want?????
There is one V6 module(V6-14). It gives 14* advance on a V6 and about 10* on a V8 with all the advance in by 2500rpms.
cuda 07-30-2007 08:57 PM
I don't know why, but I wouldn't doubt Kurt (Biggus). He knows his stuff.
SneakyPete 07-31-2007 08:28 PM
I have a used TB IV distributor, with a new cap and rotor, and a TBIV V8-22 module, that provides 22* of advance. Let me know if you want em.
Griff 07-31-2007 09:26 PM
There are 2 22* modules. One gives 22* by 3500rpms and the other 4500rpms.
For an other than stock engine with upgraded cam, I would either get a V6 module or an HP module. It will allow more initial timing and help with idle quality.
SmallPP 08-01-2007 09:36 AM
Thanks for the lessons. How do I tell the difference between modules, which one gives the advance earlier? I'd prefer that one.
My motor (5.7L, 350 Vortec Roller) is using the largest recommended Crane marine roller cam 109831 (HR-284-2S-12 IG), Edelbrock 750 carb, Edelbrock air gap Performer RPM, Vortec heads with guides cut down for increased lift, Crane recommended springs, full roller stainless Comp Cams rocker arms, aluminum GLM manifolds, thru-hull 4" exhaust. Short block is stock, but fairly high compression from 99' Vortec truck (9.5 or 10:1 if I remember right). Freshly re-ring, HV oil pump (I regret this).
This in a 1984 17' Formula, which originally had a 4.3L V6 4 barrel in it (did 50mph as tired as it was with a 25P prop).
I have so far not purchased any. Had Mallory Pro-Comp 9000 magnetic, but it has failed twice. Once just by leaving the key on! I would prefer to get one soon, and one with a V8-24 module with early advance curve to help the cam, which is a bit large, but pulls great over 4000rpm. Boat is now running over 65mph with V6 1.84 raitio and 25P @ 5700rpm, I have not had time yet to switch to 1.5 ratio.
When I start it at the launch, people come running and asking what is in it. I tell them it is a 4 cylinder, running on 3.
Those who have it for sale, please let me know or PM me. Thanks again.
rdoactive 08-01-2007 10:07 AM
The V6-14 module gives only about 10 degrees of advance because it "thinks" it's firing 6 cylinders, not 8. It determines rpm and degree advance by counting firing pulses. It also cause the ignition curve to shft to the lower rpm range.
If you get one, set your total timing at 3000rpm and dont wory about the initial. Total should be around 34 degrees depending on the engine build.
The other modules:
V8-22, 22 degrees advance in by 3400 rpm
V8-22A 22 degrees by 4400 rpm
V8-24S 24 degrees by 44000, but 20 of that is in by 2000rpm
V8-24 24 degrees by 3700rpm
V8-20R 20 degrees by 5000 rpm
These are all from Mercs manual.
Gary
Griff 08-01-2007 11:14 AM
The V8-HP module gives 20* advance and all in by 3000rpms.
SmallPP 08-01-2007 12:42 PM
Super information, thank you. I'm looking to have it all in under 4000rpm, the boat is very light so risk of knock is virtually zero. Now just need to find one used !!!
As an added note, I installed a nitrous oxide RPM switch to add a third mode of my exhauts diverters. No, I can switch them ope, closed, or automatically open above a set RPM.
