-   -   5.7LEfi overheating (https://www.offshoreonly.com/forums/general-q/164716-5-7lefi-overheating.html)
philliz 07-28-2007 09:22 PM
5.7LEfi overheating
My mercruiser 350 (5.7LEfi) is runniing too hot, especially at idle --- 180 - 190 degrees. I have a new thermostat installed, have plenty of water coming up from the outdrive, & the manifolds are cool enough to touch, so I assume water is getting out okay. The circulating pump inlet pipe from the thermostat housing is very hot however. I have taken the circulating pump apart & there appears to be nothing wrong with it.
Any ideas? I am mystified.
Fenderjack 07-29-2007 02:10 AM
what year is the motor, most efi's like to run a lil hot.
Griff 07-29-2007 03:35 AM
Verify the accuracy of the guage before you start replacing parts.
Is this a new problem???
