-   -   no power (https://www.offshoreonly.com/forums/general-q/164743-no-power.html)
awsomethunder 07-29-2007 11:45 AM
no power
hit some rocks 2 weeks ago,had to pull the motor and replace the coupler,transome plate and out drive.picked it up from the dealer put it in the water and the idle was low.adjusted idle and boat will hardly plane out and only pulls 37-3800 rpm.could something have happened to the motor when i hit the rocks?not really skipping or missing just no power.454 mag carb
[email protected] 07-29-2007 02:44 PM
is your new drive the same gear ratio as the old one?
jhiguy377 07-29-2007 02:56 PM
indeed sounds like a drive ration issue; years ago a merc dealer redid a drive for me; parts were mislabeled and drive ratio was way off- check this first- good luck - jeff
awsomethunder 07-30-2007 06:03 AM
they ordered the same ratio 1.36 but i wonder if the internals of the old where changed.even if it was a 1.50 i don't think i would be down 1000 rpm
Pwrbt33 07-30-2007 06:33 AM
Also make sure you check the prop size and diameter. Just because the drive says one thing it could be another! We just went through this with a brand new Black Thunder. Sticker said 1.5 and turned out to be 1.36.:angry-smiley-055:
Let us know what you find.
john
1BIGJIM 07-30-2007 06:34 AM
Did you check the timing?
awsomethunder 07-30-2007 07:48 AM
gonna check timing and compression today.talked to the guy that did the repair and he said he never touched the distributor so not sure why the timing would be off but i will check.just thinking if that sudden stop of the prop my have twisted anything or did it bounce on the rev limiter and damage a valve or something.the prop i had on was a 23 and this is a 25 but i pulled this prop 4800 rpm 3 weeks ago
1BIGJIM 07-30-2007 09:43 AM
A 25 pitch prop is pretty big for a stock 454 Mag.
awsomethunder 07-30-2007 10:00 AM
i will try another 23 that i have but no way is that gonna give me back 1300 rpm.if i pulled the 25 3 weeks ago i should be able to do it now and i added emi exhaust since then.
awsomethunder 07-30-2007 06:12 PM
just checked compression and timing no problems found.starting to think its in the drive.could it be that far off?
