502 Gen VI Valve Spring Pressure
Motor experts, I need some help. I am having some heads checked and need to verify the following for a stock GEN VI 502:
Roller lifters, stock cam, etc. etc. For the valve train, 1. What is the Installed Height 2. What is open/Close spring pressure for the stock springs thanks - |
Anyone??
Merc from the factory manual calls for
110 lbs on the seat (closed) 316 over the nose (open) 1.88" installed height IMO these numbers are crazy low. a MINIMUM of 130 on the nose, if not 140 |
Duke - thanks for the information, and that was why I was asking. The valve seats showed signs that the valve springs did not have enough pressure and the engine builder was recommending the 130-140 closed.
| All times are GMT -5. The time now is 09:38 PM. |
