-   -   Water Impeller questions (https://www.offshoreonly.com/forums/general-q/165290-water-impeller-questions.html)
Downtown42 08-03-2007 07:51 PM
Mine went out today. I picked up another one, installed it and smoked it again. Question: does the paddle wheel slide in easy? I had to bend the flappers 30% to get in the housing. I bent them clockwise and it was very tight but did fit after I bent them. Are the flappers supposed to be straight-up inside housing or do you guys bend them in hard to fit. Key shaft was perfect, slid right on. I gave the parts guy my serial # on '04-05 525, I hope he knew.
Also, If you have a part # I'd appreciate it. The part number I have 47-59362T Impeller. Thanks alot.
allenk4 08-03-2007 07:55 PM
Good thread on proper impeller replacement procedure:
http://www.teambajamarine.com/forum/...ead.php?t=6560
Downtown42 08-03-2007 08:32 PM
great thread. tell him thnks.
MOBILEMERCMAN 08-03-2007 08:48 PM
Good thread if you have a fuel pump on it you should change the lube while its out.
Jim
Downtown42 08-04-2007 01:43 PM
done. now it's supposed to rain I just can't win. :throw: :angry-smiley-044:
