-   -   350 MPI kill switch (https://www.offshoreonly.com/forums/general-q/165786-350-mpi-kill-switch.html)
Fenderjack 08-09-2007 11:08 PM
350 MPI kill switch
Hey guys I just put a 350 MPI engine in my stinger. I have a alpha one drive, that has a momentary kill switch in the shifting linkage for killing the engine when you shift.It did it by grounding the ignition in the carb motor .Now I have the comp.mpi motor .What wire can I use to do this same function. Can I use the kill switch wire back by the dist.Not sure of the wire color. What wire can I use. Don't want to burn anything up.I'm Lost need help. Thanks JOHN
jbbeard 08-10-2007 06:05 AM
MPI or carb no difference to the kill switch grounding ignition- just wire it back the same as before. If you not sure, have someone help by using a OHM meter while shifting to see which wire does the grounding and use it to ground the ignition as before- My best advice would be to have a qualified mechanic look at this for you !
Ford Capri 08-11-2007 03:33 AM
I had the same problem, what year is your engine?
This is what I tried.
http://www.offshoreonly.com/forums/s...d.php?t=165059
Richard
