-   -   Anyone have this problem before....... (https://www.offshoreonly.com/forums/general-q/165959-anyone-have-problem-before.html)
Spooln 08-12-2007 07:51 PM
My 95 Baja w/350 mag mpi's ran very rich after driving it for about an hour barely idles and black smoke out exhaust, but clears up after 2500-3000 rpms someone told me dirt in injectors.
MOBILEMERCMAN 08-12-2007 07:57 PM
"barely idles but clears up after 2500-3000," is a classic water in motor symptom. You should also check for signs of water on your spark plugs. Possibly leaky riser or gasket.
Jim
Trippin 08-12-2007 08:59 PM
Check your cooling system for restrictions at idle and replace the CTS before tearing into the exhaust system, check spark plugs anyway.
oldandtired 08-13-2007 12:41 AM
Purely a guess, but my first thought is MAP sensor.
Rene
Spooln 08-13-2007 07:31 AM
Check plugs all carboned up and somewhat wet (gas) Marina says he hooked it up to the scan tool no codes and all sensors working normal hopefully he's not lying, but I trust him.
I also heard might be VST getting clogged.... dont really know
satisfactionII 08-13-2007 08:49 AM
Not a clogged VST. Clogged VST will idle but fall on its face when throttle is applied. My expierence anyway.
Spooln 08-13-2007 09:11 AM
Thanks for the help everyone Just wanna still use the boat while there is time left. I'm just going to leave it at the marina til the find the exact problem
Trippin 08-13-2007 06:18 PM
Running to rich, replace CTS.
Spooln 08-13-2007 07:00 PM
It's running very rich black smoke barely idles . Would a CTS make it run that rich
Dave_N 08-13-2007 09:25 PM
When they had the scan tool on it, what was the injector pulse width at idle? Thats the first thing you need to look at to see if the engine is being "driven" rich by a bad sensor or if it's a mechanical problem such as high fuel pressure, leaking injector, failed mech fuel pump, or overflowing VST.
Dave
