mobile V-twin in mine.
Anybody know if running non merc oil would create any problems with engine warrantys ? I only have stock small blocks.
I've researched this. Merc's website states to use their oil. Then is says, if none available, then using a good grade oil is ok. However, I've heard that marine oil has additives that deter water ingestion.
Originally Posted by THLWL
(Post 2256713)
Ken |
Correct me if I am wrong here guys..and I am sure someone will!lol....but I believe the only reason you would not want to run synthetic is either...you just built an engine and you are better off on break-in with a mineral based oil.....or.. with synthetic oils sometimes the roller lifters tend to skid rather then roll because of the lubricity (too slick) of the synthetic oil..but Mobile 1 has been said to not have this problem. I run Mobile 1 20/50 in my HP500 and I can see better oil pressure with it over the syntec blend 20/50
Originally Posted by Bajapred
(Post 2258629)
Correct me if I am wrong here guys......or.. with synthetic oils sometimes the roller lifters tend to skid rather then roll because of the lubricity (too slick) of the synthetic oil..
Ken |
Well, I see where you are going with that..but in fact what happens is the roller will get a flat spot if it is skiding more than rolling and eventually end up wearing down a cam lobe.
The other reason to not use synthetic oil in a Merc 525efi is if it's still under Merc's warranty! They say no, no, no to synthetic. I got this info from the brass.
If you are worried about warranty, use a certified oil based on merc's specs. That is currently NMMA FC-W.
I'd probably go with Amsoil Marine Synthetic. http://www.nmma.org/certification/pr...asp?y=FC-W2007 Out of warranty, Mobil 1 15-50. |
Let me clear up my comments: I am refereing to Mercury Racing, not Mercruiser or Mercury Outboards. I was informed by Mercury Racing brass, that they do not authorize synthetic (Amsoil, Mobil 1, etc.) to be used in the "blue" motors while under warranty. I disagree with their stance. I have heard more than my share of arguments for mineral oil and for synthetic oil. I'll leave it at that.
| All times are GMT -5. The time now is 01:28 PM. |
