msd or carb
I am having a hell of a time getting my mag to run perfect......It seems to be electrical.....will a msd make the boat run eratic,almost like you have a severe rich condition in the motor.;....It is between the 3000 and 5000 rpm range, right where i nedd the most power...it will cough, fart and sometimes almost stall before i can get it on plane
sounds like a carb problem. Also check your timing.
Went through all that timing is perfect, no matter what i change jetting or air bleeds the problem stays there........It is real erratic....sometimes it runs graet other times runs like ****
Bad coil acting up when it gets hot maybe.
are you running a 6al or like or ar you running the tbIV |
Originally Posted by BY U BOY
(Post 2240846)
Originally Posted by nocigarette
(Post 2240862)
6al and a hvc coil, i am leaning toward the box or coil because it is the only thing i have not broken or changed on the motor in a year and a half....
Good luck |
Do you have 'blackening' inside the cap where spark has been arching between contacts ?
I had a pro-billet distributor with excessive corrosion on the trigger rotor and magnetic pick-up that gave same symptoms. I too chased thoughts of fuel issues, turned out to be ignition breaking down above certain RPM. |
Nosmokes, I am chasing a similar problem with a Crane box. Spoke with a person who suggested and has seen electric fuel pumps kick out an RF signal the pizzes off the igntion system. Might try running 12v straight from the battery to the coil. Just be aware turning off the key will not stop engine, got to hit the batt. switch to off or switch from 1 to 2 etc.
Originally Posted by BadDog
(Post 2241356)
Originally Posted by Kelly O
(Post 2241293)
| All times are GMT -5. The time now is 02:30 PM. |
