ECM3 to a 4
Can a ECM4 be made to work inplace of a ECM3
Yes, you just have to re-arrange the pins on the wiring harness since the MEFI4 pinout is different. Also have to get the 4 set up with the same configuration.
I have switched from a 3 to 4 a month ago and its working fine. |
Advantage 27
Where can i get the pin configuration information. |
Were you ever able to get the information to do this?
I have the pinout to go from a 3 to a 4 if you still need it. Give me a shout and I can send it to you.
Eddie |
Not trying to hyjack, question along similar lines, can a 555 on a 496 be replaced with a properly programed MEFI4 ?
Is there a harness/plug adaptor that plugs into the 496 harness and changes the 555 plug to a MEFI 4 or am I talking out my as$.....? :coolcowboy: |
Tt
Originally Posted by FogduckerIII
(Post 3596052)
The only way to replace a 555 with a mefi is to change the harness. There aren't any adapters to convert it. The wiring harnesses are totally different.
Eddie |
Originally Posted by Young Performance
(Post 3607759)
Eddie |
Hey Jer, the harnesses are available from a couple different manufacturers, Volvo, Marine Power, Kodiak. Merc was the only one not using a MEFI on the 496. I've got the HO base program I can send you if you need it and may have a harness too. I'll check and let you know.
Also, Dustin has a proven program for the 496 Procharger combo too and you could keep the 555.
Originally Posted by HaxbySpeed
(Post 3607797)
| All times are GMT -5. The time now is 10:29 AM. |
