Originally Posted by SB
(Post 2243891)
With an upgraded cam and old (1977?)Merc exhaust I'd look into possible water reversion and/or intrusion possibly causing that exhaust valve failure.
(Post 2243891)
If you don't have OE exhaust from that era, mention what exhaust it does have.
(Post 2243891)
As Kaama mentioned, RM does many perf marine cams and has many years of data.
The RM exhaust is a good low budget upgrade. I doubt you will be able keep the Qjet. the intake may be ok. I'm not sure what comes on the 400.
I another guy specs I used when I hopped up my 454mag. He used the cam I posted and did a few other mods. He dyno'd at 42hp @ 5000 rpms. Probably could have pulled 440-450hp with some more rpm. Here's one of the threads. http://www.offshoreonly.com/forums/s...ighlight=Griff |
As an interesting expample of a 454cid marine engine.....about 5-6 years ago my cousin modified his Merc 330hp engines and used an off the shelf flat tappet hydraulic cam...218*/226* on 110* lobes, old semi open chamber oval port GM heads that he had JimV install 2.19" intk/1.85" exhaust valves and did some bowl/shortside radius porting, Holley carb on top of a dual plane aluminum hi-rise intake manifold, bore notched the cylinders for better flow around the valves, 8.6 comp ratio and made 461hp @5100rpm on Tom Earhart's dyno with car style tubular dyno headers. The engines made 510 ft. lbs. of torque @3600rpm.
He installed the engines in his 1988 32' Baja with GIL exhausts (dry), went from a 21" prop to a 25" prop and picked up at least 10mph in the midrange cruise speed and on top. |
| All times are GMT -5. The time now is 09:41 AM. |
