-   -   cooling problem (https://www.offshoreonly.com/forums/general-q/166856-cooling-problem.html)
later 08-22-2007 01:19 PM
cooling problem
have a friend that has a 97 4.3 efi with a bravo three out drive, water tempeture goes up to 185-190 then will drop back down to 120 then a few minutes later rises back up the 185-190 and then will drop back down to 120, this is after he replaced the seawater pump because of a bad impeller, he then replaced the circulating pump and thermostat, any ideas.
also does any one have a serpintine belt diagram for this motor to make sure he has the belt on properly.
thanks in advance
later
handfulz28 08-22-2007 01:31 PM
Somethings wrong in the t-stat housing or possibly the water flow. I had the same thing happening and ended up putting a new housing in; fixed it.
jhiguy377 08-22-2007 02:46 PM
indeed that kind of fluctuation would seem to be thermostat based. good luck - jeff
rdoactive 08-22-2007 02:51 PM
I've seen similar problems caused by a bad head gasket. A quick check of the plugs will rule that out.
1BIGJIM 08-22-2007 03:07 PM
Did you back flush the system to get all the little rubber impeller parts out? I am willing to bet that is your problem:D
