-   -   K-Planes goes down but not up (https://www.offshoreonly.com/forums/general-q/167342-k-planes-goes-down-but-not-up.html)
Velocity Vector 08-28-2007 12:32 AM
One side K-Plane will go down but will not come back up. Other side works up and down.
MILD THUNDER 08-28-2007 06:16 AM
Bad solenoid on the pump. 20 bucks
CAVelocity 08-28-2007 12:10 PM
Could also be loose/broken wire to the solenoid....
Reckless32 08-28-2007 01:07 PM
At the pump, take everything apart and clean it up with a brass wire brush and re-connect everything. Corrosion is usually the culprit on things like this, or for most simple things on boats in general.
Regardless, start with simple first.
Velocity Vector 09-02-2007 11:44 AM
Thanks guy's
