-   -   New Temp alarm units for Closed Cooling 454 Mags (https://www.offshoreonly.com/forums/general-q/167665-new-temp-alarm-units-closed-cooling-454-mags.html)
shotjock 08-31-2007 12:01 PM
Hello,
I bought a freshwater boat Scarab and brought down to FL so did closed cooling right away. But it runs @160-180 instead of the usual 125 degrees so the alarms keep sounding.
1. Is this even good for the engines since spec is 125 degrees?
2. WHERE can I find new Temp alarm sensors that will fire off at a higher temperature?
THANK YOU from a new boater!!!
Frank
