-   -   Ran over rope! Won't start :( (https://www.offshoreonly.com/forums/general-q/168071-ran-over-rope-wont-start.html)
H2X BOSS 09-06-2007 12:26 PM
Took my friend and his son for a quick ride in the new donzi 16. Idling towards dock, my rear rope had fallen in the water, wrapped around the prop and stalled the motor. Idiot move for sure :(
After removing rope, engine will fire up but die instantly no matter if fast idle is used or not, primed or not...
any help would be great.
it is a 2005 merco 5.0L carb, stock
thanks
txriverrat2001 09-06-2007 12:36 PM
Alpha drive?? If so - check the shift interupt switch and make sure it's centered in neutral...
cuda 09-06-2007 12:42 PM
I don't know your solution, but that's exactly why my handling lines are floating lines.
Good luck.
