Stainless Marine HI-TORQUE manifolds
Anyone know if the Stainless Marine HI-TORQUE manifolds (not GEN III's) will work on 540 ci (600+ hp) motors? Just trying to plan ahead:D
Thanks |
They will work on any BB. WIth "standard" BB heads. Your only issue may be depending on the heads you use, if the exhaust lines up with the current holes.
Quote:
I'm using them on a 500 CI motor blower motor W/ Canfield heads 350cc runners 850++ Hp. All is well, breathes like a dragon...
Quote:
Thanks :drink: |
Does the stainless stuff work with the more pedestrian, standard, run of the mill through the prop bravo 1 setup?
In other words, my mercruiser manifolds are coming up on 8 years old. These would be the last manifolds I would have to buy ever, right? EDIT: Nevermind. Just saw the price! |
Quote:
Quote:
Quote:
I`ve got the Hi-Torques on my stock 502. They are awesome.
I had a pair of Gen III`s on a stroker engine I built a couple years ago. These are monsters !!! |
Quote:
Quote:
Quote:
Quote:
How do you tell which manifolds you have?
The threes have individual runners all the way through the manifold and extending into the collector, you can see it on their web site. The high torques (earlier), only have the runners part way up the manifold. I had to get these because I needed to twist the collector pipe to a side outlet.
| All times are GMT -5. The time now is 08:03 PM. |
