-   -   towing a 29 outlaw (https://www.offshoreonly.com/forums/general-q/168261-towing-29-outlaw.html)
hausbfc 09-09-2007 10:08 AM
towing a 29 outlaw
I have an 02 1500 silverado with a 5.3 and I am looking at buying a 29 outlaw.I have been told that the truck will pull it and that stopping is the issue.I have a superspring on the truck to handle the tongue weight.The trailer that the outlaw is sitting on comes with triple brakes not double.Will the triple brakes make this boat towable without me having to upgrade my truck
fountain4play 09-09-2007 10:48 AM
If it were me, I would upgrade the truck first, I can see some issues on using a 1/2 ton to pull that large of a boat.
The transmission is the first thing to come to mind, depending on how far you plan on towing your boat, they don't hold up extremely well in my opinion...
Just my $.02...
twin242ls 09-09-2007 12:38 PM
what kind of towing are you doing? back and forth to ht elocal ramp or are you headed on a tour of the country?
a half ton will get it done.
however A set of airbags in the rear and a shift kit in the tranny. 373 gears may be pushing it, but 410's will definately get it done.
Formula has a 292 they are sending all over the country being towed by a half ton chevy. check the formula forum they give alist of upgrades to the truck to make it
I tow a twin engine 242 , 27loa with a half ton z71 avalanche, boat loaded with fuel on galvi trailer is just about 9k. boat wet is just under 7k and trailer is 1,800 a good set of trailer brakes make all the difference.
a couple of small upgrades and you will be ok.
but if you plan on long trips you may want an upgrade
Elite Marine 09-09-2007 12:46 PM
What is the tow rating with your power in the truck. "Can" tow it is much different than "should" or can "legally" tow it.
It you are over the tow limit of the vehicle and have an accident, you are not covered. Just something to think about.
jafo 09-09-2007 05:21 PM
Bingo- Give an insurance adjuster one reason to NOT pay a claim, and they'll take it. Today's truck engines have good power, gas or diesel. However, you don't get into brakes with adequate load-stopping power until you're into a 3/4 ton or larger.
JohnnyG 09-09-2007 08:03 PM
Whether or not your 1500 is rated to handle the load is one thing. Durability and longevity of the transmission and engine is another thing entirely. I used to have a Tahoe with the same motor and transmission as you have. It towed my 25 footer ok, but I can't even imagine trying to tow our 32 footer (not that much bigger/heavier than a 29 Outlaw) with it. Granted your truck has a longer wheelbase, but that wasn't the only issue towing with the Tahoe. It was working very hard to tow us up hills and braking was marginal.
Also, be sure to double check what your hitch is rated for. It could be as low as 5000 lbs weight carrying if I remember correctly, which is WAY too low for a 29 foot Outlaw. Another insurance pit fall that some people don't think about.
If it were me, I'd upgrade to something that won't be at the max while towing your new boat. You'll have peace of mind that you have enough truck to handle the load and it will last a lot longer too.
John
articfriends 09-10-2007 01:01 AM
A buddy of mine had a 2000 29 outlaw,he towed it once with his half ton z-71,it threw it around like a rag doll. He said on damp pavement until the brakes took up on the trailer it would skid the truck like it was on ice. He bought a 3/4 ton 4dr w/454,it still worked to pull it,especially if boat was full of fuel,Smitty
yamahayz26 09-13-2007 07:36 AM
I have a 1997 29 outlaw(approx 8500lbs in tow), and pull it with a 3/4 ton duramax. I couldn't imagine trying to pull it with a 1/2 ton. I am pretty sure it is over all of the limits on the 1/2 ton. I would recommend upgrading to a 3/4 ton before conquering the 29 outlaw.
Just my opinion.
Griff 09-13-2007 11:57 AM
I would not tow a 29 OL with a 1500 unless it was a single engine. Even then it would be borderline.
Dd24skater 09-13-2007 12:47 PM
That's allot of boat for a 1/2 ton
