monstaaa 500
blower, cometic head gaskets, new head bolts, good fuel, 700 plus h.p , and hold it. DITTO!!! I cant tell you how many head gaskets I have replaced that are trashed on stock 500's, including EFI's! Do yourself a favor and do the above. John |
I also did a complete port and polish on my heads and my intake manifold to make them match up better..and flow better...but one other thing you will need to look at is your fuel delivery...you will need to work your fuel pump over to make it flow a little more fuel..or buy a higher volume pump...I just drilled mine out in all the right places and tried not to use any more 90* turns than were needed..my fuel pres. never gets below 6 now.
Originally Posted by Bajapred
(Post 2268372)
Originally Posted by Canada Jeff
(Post 2268544)
Below 6 what?? Not lbs...
Remember , talking about carbs. My fuel pressure stays between 7-9 PSI also. Darrell. |
Right, getting two threads mixed up.
Yes..stays mostly at 7 PSI..but will go as low as 6 in full boost...you do not want it below 5 ever
Originally Posted by BLOWN85
(Post 2264819)
Hey guys. I have a 500HP in my 280 Velocity and want to put a blower on it. My buddy had a Wieand 256 with dual 4's he is getting rid of so he can put an 8/71 on his engine. My question is, Can I bolt this blower on to my engine or will I have to change pistons and cam? I am looking to boost around 5psi with it. I believe that the 500HP is 8.75:1 compression?
$3500 is a steal for a good 650hp, after that, your going to double your investment. New SC, with IC, new carb, etc. Forgot to add, with 5-6psi, set max timing at 28-30deg. Stock module has 34. Thanks |
| All times are GMT -5. The time now is 11:48 AM. |
