Why not extended tip plugs on S/charger
I read somewhere not to use these but i've had good luck running the AC r42ts plug. I'm I missing something?
Originally Posted by kennyo
(Post 2271432)
They say the tip can get hot and cause detination,that its stick out into the chamber. But in a bot with verymuch idleing the non will load up. I my race car stuff i run non pro tips with the nos . I run them at 8.5 pds on 93. |
I ran extended tip plugs in my hopped up 525SC. I used NGK UR5's. Same heat range as an AC 41.
Originally Posted by Strip Poker 388
(Post 2271719)
procharger says not to run extended tip plugs with a blower,it was the only way I could keep them from fouling so I chose to ignore there advice and I have never had a detonation problem,Smitty
I was told by a Champion rep at Daytona that extended tips are cooled by the incoming air charge.
Randy |
Originally Posted by articfriends
(Post 2272580)
| All times are GMT -5. The time now is 09:54 AM. |
